DVDFab Blu-ray Ripper can be used to rip 3D Blu-ray to 3D AVI with fast speed, high output quality and great 3D effect. It’s very easy to use and the conversion can be done with only a few steps. Let’s go to have a look at the whole operation.
Step 1: Start up DVDFab 9, choose Ripper option and load in the Blu-ray movie
Start up DVDFab 9 and choose Ripper option. After Ripper interface shows up, just insert the BD you want to rip into the optical drive so that DVDFab will load it in. Seconds later the movie will be in and the longest title will be selected by default. You can easily change the audio tracks and subtitles.
Step 2: Choose an AVI profile
Open Profile box to navigate to 3D Format to choose the avi format. Then go to choose a profile for the output 3D video.
Step 3: Set video parameters and effect
Click Advanced Settings button, then go to 3D tab in the following pop up, where you can choose the 3D format. You can also go to Video tab and Audio tab to set video parameters and audio parameters.
Hit Edit button on the main interface to open Video Effect window, where you can resize source aspect ratio and frame resolution of the video, or crop the image for display.
Step 4: Hit Start button
Hit Start button on the main interface to start conversion. During the process, all detailed progress info can be monitored.
OK. Done. More info of DVDFab Blu-ray Ripper can be found at: https://www.dvdfab.cn/blu-ray-ripper.htm
